89 force ob 125
roofer11
had boat running great.put boat in water next day,wouldn't start.cranked fine.found that i had no spark on two cyl.checked wiring and connections.anybody have similar problem?could use some input.
jerryjerry05
Re: 89 force ob 125
Check the compression.More details.What 2 cyl dead?Fill out the profile,you might be close to someone who can help.
Ethanol is messing up a lot of motors.It's delaminating the inside of older hoses causing clogs in the carbs and fuel filter.Check for soft hoses and junk in the filter on the motor.Check the diaphram J
