Re: 88 force 125 ?
Remove all of the wires off of the terminal strip.
Okay, The BLUE CDI will control cylinders 3 & 4. Make these connections:
Blue : Connect to Brown/Blue from stator should have a #3 on it
Red : No connection for this wire, just put in on one of the terminals by itself
White/Green : Connect to White/Green from trigger with a #4 on it
White/Orange : Connect to White/Orange from trigger with a #3 on it
White/Yellow : No connection for this wire, just put in on one of the terminals by itself
Brown/Yellow : Connect to Brown/Yellow coming from stator with a #4 on it
Make sure that the wires from the center of the CDI are: Orange connected to coil #3, Red to coil #4, White to terminal on the other side of the motor, and Black to ground.
_______________________________________________________________
I have never used a black CDI PACK, I did a little research and it looks like people have used them before; however, it seems like you are missing a wire. You stated a White, Red, Blue on the top, the white wire should have green on it or there should be a wire on top with green on it. The solid white usually goes to the other side of the motor on the terminal and is located on the center of the CDI. Can you take a picture of the back side for me?
Assuming that green strip wore off of the top "white" wire, this is how you would wire the Black CDI:
The Black CDI will control cylinders 1 & 2. Make these connections:
Blue : Connect to Brown/Blue from stator should have a #1 on it
"White" : (should have a green somewhere on it) : Connect to White/Green from trigger with a #2 on it
Orange : Connect to White/Orange from trigger with a #1 on it
Green : No connection for this wire, just put in on one of the terminals by itself
Yellow : Connect to Brown/Yellow coming from stator with a #2 on it
Make sure that the wires from the center of the CDI are: Orange connected to coil #1, Red to coil #2, White to terminal on the other side of the motor, and Black to ground.
-Mark
