best replacement 460 king cobra
Steve Mahler
i am hesitantly looking at a boat with a bad 460 king cobra. knowing all those fine issues, i would be converting to mercruiser....so, would an alpha one fit the king cobra cutout, or is it too big?
HT32BSX115
Re: best replacement 460 king cobra
Howdy Steve,
We might need a little bit more info.
How big is this boat?
Just an aside, when i pulled the 460 in my current boat I wanted at least the same performance with any replacement.
A replacement that has an ALPHA behind it will probably not perform as good as the 460.
The 460 is a lot of things, good and bad. Performance WAS NOT one of the bad ones!!
Oh, and to answer your question. YES an Alpha will bolt right in. If it's a GEN II or a Bravo, you need to drill 2 additional holes at the top of the cutout.
See the pictures below for comparison.
Liberator with King Kobra
Liberator with 454/Bravo III
Cheers,
Rick
Steve Mahler
boat is a 28 bayliner, really needs a 454/bravo; but i know they can modestly perform with a 350 alpha...i am hunting around for prices/donor boats.
HT32BSX115
That's a pretty big heavy boat.
Don't expect anywhere near the same performance with a "350"
You might get close with a 383, but I wouldn't put a high HP engine in front of an Alpha on a cruiser type boat.
I paid about $5K for my 454/Bravo III. I also was able to sell all the King Kobra "stuff" part by part for about $3400 so far.
My suggestion for a 28' "anything" is a Bravo III (or a Volvo DPS if you can find one.....I looked and found a LOT of Bravos.)
Good luck!
Rick
rodbolt
if your drive is in good shape you can go with an 8.1 or a 6.0 GM.
use the omc bell housing from a GMv8 cobra or SX,use the front mounts from a GM v8 cobra or volvo sx.
the 7.4 has been out of production since about 2003 and finding a good complete unit is hard.
