1989 bassbomber
Thread starter- Joined
- Jul 30, 2010
- 3
i have a 1989 mercury xr4 150 on my bass boat.i have about 2lbs of water pressure at idle and about 15lbs at wot. i have replaced water pump.thermos are good and checked poppet valve. boat runs almost 1/2 on temp gauge in barrel or water hose.goes down to 1/4 when reved up. my thing is the water coming out pee hole is steaming hot.puddles on ground still steaming. took boat out couple of weeks ago and it would run hot enough that the buzzer would come on. so i came home pulled heads and gaskets were seeping. put new gaskets on and still steaming. is it normal for the water to be steaming hot? (can't hardly touch it) also it shoots about a 2ft stream out the pee hole. please help thanks
