probeklze03
- Jul 28, 2010
- 10
Re: Need help from experienced boaters
thanks for the advice, one of my employees said the same thing about the epoxy,says it happens to alot of boats where to pieces mate. tires look good and trailer has new axel which i will grease before moving, also i was told to check exhast hoses?
not reel exp. on boat but glass ane engines i am. do not run the gas drain dry vacuum then put fresh gas in with some sea foam, spray carb down wit carb clean and alow to evap before starting. and check for leaks on all seals and lines once running. sitting that long you might need a carb rebuild. as far as glass goes anything can be fixed the question is how to go about it, sounds like a cap to hull disbond, get some epoxy that they use on corvettes to bond back to gether. can go into more detail later if needed. 4000 a lil steep in this econo shoot for 3000. there will be more wrong than you think wit a boat sitting that long, seals like to get hard and draw up sitting like that. also trailer tires will prob have flat spots.
