Re: 1979 Evinrude 115 Idle Trouble
Ummm....
First thing that stands out....look at the ends of the piston pins...wow...those are really coked up. (Carboned up). I never saw any that bad. Really. And what is with that cylinder rust? Has this set up for a while? If rusty, you will have to bore it, I think.
But anyway, that engine ran coked up, broke all kinds of things...
I just repaired one that did the same thing. STBD side and all. Truly. I did it on a shoestring budget, and cut all kinds of corners, and the darn thing runs great.
First off, I measured the bore damage. It was within specs to simply hone out the really bad looking stuff. Guess what? I left two serious scores (one in each cyl) per the owners request. Your scores are much worse that the ones that I left. You could barely feel them with your fingernail, but you could absolutely see them. I also hand chamfered the gouges in the ports left by the broken rings. I just kinda smoothed it with the air die grinder. The owner didn't want to bore the engine...no money.... I split the crankcase, never disturbed the port side at all. Port head stayed on, as it had good compression. Crank stayed in. I honed the stbd side with the crank in place, used a simple three stone drill powered hone and plenty of oil, and replaced the two pistons with Sierra STD pistons and rings, (even tho there were two scores in #1 and #3). I re-used all the bearings, put it back together, fired it up and it is good right now with 120 psi all around and strong running, steady idle. The only new parts were the pistons, rings (2) sets, and the associated gaskets.
Only one thing...don't use Sierra gaskets, I learned, and I am not real pleased with the Sierra thermo kit. I truly believe the Sierra springs are weaker than the Evinrude springs, but I am not sure yet.
Yes you can only do one side. I cut major corners. I am NOT recommending you do the same thing. I am simply describing what I did to get the motor running for my friend. I had to look out for dirt and debris, honing slag, etc. But yes, you can only do the stbd side if you want. Most shops will not guarantee anything like I just described.
Examine what you have and proceed with your best feel, based on other's recommendations.
I BET I GOT LUCKY.
