Hi all,
I hope someone can help as two mechanics now have not been able to.
I have an 87 Cooper Prowler with a Mercruiser 260. I have a problem with the throttle and getting to WOT. When I reach 1/2 WOT, the motor sputters, catches itself and bogs to WOT. The RPM's reach only 3100-3200 at WOT. The entire 2nd half of throttle is a bogfest. I have in the last 4 years had the boat get past this problem about 5 times and RPM's reach 4200 and boat reaches 21 MPH. ALL the other times, I top out at the 3200 RPM and boat reaches 11 MPH.
According to the two mechanics it has been into see, the fuel pump is working propery, engine compression is good, plugs have been changed, carb rebuilt, distributer cap replaced, fuel filters changed and timing is good.
The boat starts wonderfully, the first 1/2 throttle runs wonderfully, BUT the 2nd half throttle is bit problem. There is a smell gas when idleing.
Anyone have any ideas? I suggested changing the fuel pump but the mechanic says the pump is working fine. He now ways that it could be water in the tank as he did find some.
One last tidbit. I hooked up a 5 gallon external tank to the fuel line that enters the fuel pump and ran it on that for a while, went WOT and same old thing. I then pumped the bulb to try to get more gas to it...no change. I would think that this would eliminate the water in the tank possibility.
