rickryder
- Jun 24, 2010
- 2,722
Hi
I am trying to get my old 55 HP 557 hg to run properly. I could hear it wasn't really running on both cylinders so I started trouble shooting from the plugs back. I did a compression test and read the plugs,top plug looked great bottom looked almost new not much burn going on. My compression is 127 in both cylinders. Next step was to ground out each plug,top made motor miss bottom was no change. Checked switching wires same results,switched coils same result when bottom cylinder is grounded there is no change in motor run-ability. My question where should I go next?? Points? Only strange thing is if I test for spark with a screwdriver in the lower wire to ground I have spark
Anyone have a suggestion?? Thank You
