hondakillrsx
Thread starter- Joined
- Jul 8, 2009
- 70
Hey guys I've got yet another problem now (pretty soon I should have just about everything replaced). So this problems seems to have gotten steadly worse and worse over the last few trips. What happens is the boat will not plain out, it tries to but just doesnt seem to get the prop spinning at a fast enough RPM to get up, then after a few minutes of putting the load of trying to plain out on the motor it over heats.... I'm not a boat mechanic by any means but it seems like it has to do with something in the lower unit or prop. The reason I say this is the engine itself runs fine and revs up great like it always has. I checked the compression on both cylinders and its reading perfect at 150 on both cylinders. I don't notice any binding in the lower unit when its in neutral but i will say that the bottom piece of the lower unit that guards the prop from smacking the ground is broke off and I've hit the prop more times then I can count so I'm thinking something is off in the lower unit or maybe the prop is screwed.... Any help would be huge. I found a used lower unit on ebay for a 160 bucks but its a long shot that that would work. Has anyone else had this problem? I could be way off here so please throw your two sense in, I'm all ears...
Lane
Lane
