Dan Salvin
Thread starter- Joined
- Jul 21, 2010
- 39
I have a small Mastercraft trailer from 1971. I use of for a 14' aluminum Starcraft. Often, the passenger side of the trailer gets stuck down (so the boat is tilted toward the passenger side), like the leaf spring does not spring back. If I pull up on the trailer, it pops back up to be level with the other side. The leaf springs are fairly rusted. I assume the spring is shot and first thought I could replace the leaf springs but now see that they appear to by welded to the axle in addition to being attached with two U bolts and a metal plate. Is there any way to replace the leaf springs and shackles without also replacing the axle? Thanks.
