Home Cookin'
Thread starter- Joined
- May 26, 2009
- 9,715
I understand that you should not rev your outboard up in neutral or on muffs. I'm going to wrench on a 20+ year old Johnson 70 this weekend in the driveway, looking for a short that occurs at higher rpms (3-4K) so I would want to give it some short bursts while watching the circuit tester meter, etc.
Am I really asking for big trouble or can the motor handle it under these circumstances? Is the issue that it doesn't pull enough water and will overheat, or that without a load it can run up to extremely high RPMs? If so I can watch out for either circumstance. I'll add, too, that I don't know how accurate the tach is, but I have a pretty good ear for a motor that is over revved.
I had an old 70 OMC that was very cranky to start and often got that screaming start. Nothing bad ever happened that I could tell; got 20 years out of it.
