westofthey
Thread starter- Joined
- Jul 15, 2010
- 1
I have an 89 Wellcraft with a 350 Mercruiser, Alpha 1 outdrive. Like the title says I'm a total boat newb, 1st time owner! I have a few issues with my boat and it's going to the mechanic tomorrow. I was just wondering some possibilities of what I might expect from the mechanic.
1st, the boat is not holding an idle. It seems I can idle all day long on the muffs in the driveway but once I get on the water, totally different story. When I slow down from higher speeds it will die and when trailering or beaching the boat I can't shift from forward to neutral and into reverse without it dying. Starts fine, throttle up in neutral, and in gear and moving no problems. I have had the oil changed and I've replaced the fuel filter. I'm also running the boat at higher elevations (about 1000ft) than the previous owner. That's the only maintenance I've done to this point.
2nd, after doing some research I'm sure my bellows is missing as I can see the drive shaft running from the main engine into the outdrive. Also the shaft sounds as if it grinding/scraping on something.
3rd, and finally, when I throttle up to take off and stay on plane the engine rpms go way up...off the tach and don't come down when on plane. Don't know if it's the tach or if something is slipping causing the rpms to spike. It doesn't seem to be running as high as the tach says and it doesn't seem to be over revving.
Thanks for hanging in there for my long post. And thanking you in advance for you patience and replies. I realize that there could be multiple problems inside each problem I mentioned. Just wondering what I might possibly hear from the mechanic, just so he doesn't try and blow smoke in my direction.
