1972 Johnson 9.5 hp
Engine has very few hours on it, probably less than 150 hours. Inherited from father in law. Engine sat for about 10 years with almost no use.
Changed the lower unit lube and used new gas and it started with two pulls of the stater rope. Ran well for several trips. Used it to go a short way onto the lake and it started and died. Restarted with effort but ran okay. When I wanted to return to shore, it started with one pull and died almost immediately. Would not start again even though the starter rope pulled easily. Went to check on it the next day and the starter rope would not pull. When I took the spark plugs out, water came out of the bottom cylinder. When I pulled the starter rope, water shot out of the lower cylinger and continued to do so as long as I pulled the starter rope.
Now the question, what should I check to find out how the water got into the cylinder? I have visually checked the head gasket (external only) and it looks like it is sealed very well with no breaks.
