Re: well my motor is shot!!
You need to learn a lesson from this. There's no way you ran with a blown head gasket without symptoms. At that point you were looking at head gaskets, maybe a used head, depending on what went wrong, and probably catching up on preventative maintenance, like a water pump impeller.
Now yer in the market for an engine.
These engines run reliably on the hairy edge of destruction all the time. At the rate they burn fuel, they will live for seconds with a cooling failure, and similar time with oiling failure. they will fairly quickly melt down with a "minor" fuel problem. They are engineered with a bit of margin, like phat fuel mixture for instance, but if you run them over the edge, they will grenade.
The lesson. Maintenance is cheaper than breakdowns.
