DaBrickster
Thread starter- Joined
- Jul 1, 2010
- 12
Had a crack in my 57 fastwin 18 gear case. looking back I should have just used some marine tex, refilled with oil and kept going. But I wanted to make sure the gears were fine so I separated the gear housing and lower unit. I have a friend who welds alum. so he repaired the crack. I inspected all the components and everything looked fine so I reassembled the gear housing and the lower unit. I have read others threads about the linkage so I made sure the rods were connected. Using hand power the prop turned freely in neutral, and and locked in forward and reverse. I felt great about a job well done until I got on the lake and tried to put it in forward. It did not engage. Reverse and neutral just fine. Does anyone think that this is in the linkage or maybe in the gear assembly? Any help would be appreciated.
