OMC Prop 14x18 3 blade
getemracing
My prop broke this weekend. The center hub is spinning inside the prop. Looking for a 14x18 3 blade prop for a OMC part # 381187 for a 155hp i/o. Is there a better prop or a different replacement that would work as well? The boat is a 1969 Johnson tri hull.
usskydvr
Re: OMC Prop 14x18 3 blade
Are you thinking that there may be a better brand than the original OMC?
Either way I have had good luck with Michigan Wheel Props
usskydvr
Yes. Your local prop shop should be able to do that.
