2003 200hp ficht engine problem
pep25
When I turn the key on it goes through the engine self test and then the no oil,hot ,check engine light come on.
seahorse5
Re: 2003 200hp fitch engine problem
Those 3 warning lights are turned on by the engine computer, EMM, and it is faulty. The 4th light is the LOW OIL and that signal does not go through the electronics on the motor, it's just a float in the oil tank.
Your dealer can exchange the EMM with a factory unit or you can contact www.dritechnologies.com for repair of it.
pep25
Thank you i will look into that
