5.0 Mercruiser no spark
Racinmike77
I just bought an 89 maxum and on the water it stalled out. I could not refire and found I have no spark coming from the coil. Replaced Coil and still have no spark. Is there possibly a bad module or a bad condensor? I am not very familiar with boats so where to find these parts and troubleshooot will help.
aktrucker
Re: 5.0 Mercruiser no spark
Check the voltage at the coil with the key on....
Bt Doctur
posting what type of engine and drive will help get a better answer
wnaplay
Good luck. I have posted this same question on this exact same boat already.
Don S
Don S
So, have you tested the system and found that to be the problem? Or are you planning on throwing parts (aka $$$$$) at it till you finally replace the right part. Which could actually be a bad connection under the helm and not a bad part?
Racinmike77
I have already tried a new coil, I do not see a bullett connector coming from the distributor. A quick walk through would be nice, I have a test light and a Noid light ready to rock.
EDIT: Phone numbers and email addresses not allowed on forums
Don S
Noid light ???????
Got a Merc serial number of your engine handy? Is this EFI or carbed?
Racinmike77
it is carbed, Where can i find the serial number? Have spark checker handy. No fire coming from the coil.
