Switching props?
mmwest
Any sugesstions for a new prop, i have a 2005 sea ray sport 200 21' mercruiser 5.0 alpha 1, learning wakeboarding so hole shot propably what i'm looking for verus top end -- stock prop is 14.25/21 3 blade.Looking for options w/4blade alum vs stainless,and after all that now what's the best brand for the buck. THANKS
usskydvr
Re: Switching props?
Really need to know wide throttle (WOT) RPM with normal load. ( no wakeboarder being pulled). General guess would be a SS 19 pitch 3 blade or 18 pitch 4 blade. check E-bay for a good used prop.
mmwest
Thanks,my problem is I had my lower unit replaced by Marine Max ,they installed my current prop which is an Express from Turning Point 14.25/21 ,now five years later it does'nt fit,GO FIGURE THAT, something about the retaining nut going on.I've had the worst of luck dealing with these people since year one of new purchase,I told them to just give me my boat back---it'd been in the shop from 6/28 till today to fix existing problem that they screwd up on. FIVE STAR REPAIR CENTER MY A## , SEABROOK TEXAS MARINE MAX
mmwest
Just dug up paperwork on my mercruiser and the wot is 4400-4800.Is a 14.25/21 a suitable prop for casual tubing and wakeboarding.Just trying to figure out which prop to put another $300.00 or so on.
junior1113
4 blade props are awesome for what you need. need to know what your current wide open throttle rpms and speed are with the prop you have.
usskydvr
Ok, so we now know the 'recommended' WOT. What we need to know is the actual WOT you can get with your current prop.
mmwest
I'll check this out tommorrow 7/17
mmwest
my current wot is 4200 with a 14.25/21 prop
mmwest
will that kill my top end that much,and do you think the 4 blade is maybe a bit too for my boat. remember i'am just a recreational wakeboarder and tuber but i think that would really help my hole shot. thanks
dirtyoldman
If you're only doing 4200 RPM at WOT, I don't think you'll find a downside to swapping props. You'll be changing the effective "gearing" but will find more rpm at high speeds, which will cancel each other out. You may find more top speed with a 19 pitch.
ryanr623
This is true. Plus better hole shot.
fossill
For watersports the Merc High 5 is the only way to go. You wont be dissappointed.
