Good Day everyone..........
Randomly, when turning the key on, the buzzer in the control head will sound steadily. Start the engine, steady stream from water pump discharge hole. After 5-10 minutes the alarm clears. I believe the sensor is located in the upper outboard port cylinder head? Separating the wire at the junction does not clear the alarm.
Thoughts? Does disconnecting the sensor cause an alarm or create an alarm? Since most sensors create a path to ground, I would think that unless there is some sort of wire-break protection, opening the circuit should clear the alarm.
BTW, intermittent alarm is oil, steady alarm is temp related.......right?
Thanks, Paldin51
Thanks, Paldin51
