Re: transducer woes
What kind of boat? If fiberglass, you can remove it from the transom bracket and epoxy it in the bilge area provided your hull is solid and has no voids. Even "skimmer" types will work this way. Better yet, get a shoot-thru model and mount in per instructions. I put mine in the bilge a few years back and eliminated all the issues with transom mount units.
If you have an aluminum boat, look for an "alumiducer" as these are designed to shoot thru aluminum. They work well and run about $75.
