Classic fifty stalls in gear!
Dotong
Hi again,
Ive sorted all my problems so far from this forum so im hoping to sort this one too(maybe this will the last to sort, and il finally have a decent outboard!). My outboard starts and runs in neutral fine it will rev up on the warm up perfect, it will idle all day in a barrel. As soon as i put it in gear and give it throttle it will die. Itl go into gear at idle for a few seconds but as soon as i rev it it dies! The carbs are recently cleaned and there is a spark at all four cylinders. its getting fuel ok as the bulb stays hard. Any ideas? The only thing ive noticed is a very small drip from the bottom carb, could this be it??
Cheers
Dotong
Re: Classic fifty stalls in gear!
ok,
just an update on things ive tested tonight. compression test showed 40psi on all cylinders which i guess is wrong or it wouldnt run(would it?) must be a dodgy tester. there is exhaust gas coming from behind the fuel pump, what would this do?
Cheers
