Motor ran fine last week on the water for hours, did a fresh water rinse when done playing with no issues. Now today while on the muffs, it is running away! Here is what I did so far to diagnose issue: Pressed electronic choke in while running and it started to caugh and wanna die. I ensured the butterfly linkage was not bound up and the butterflies were closed. I manually pulled the throttle linkage back some with very little difference. All 3 cylinders appear to be same temp by touch. Ensured good fuel. Manually engaged choke lever and killed the motor. I am lost. I did hear a weird sucking sound out of the bottom cylinders carb as the motor was laboring to run at one starting attempt, then the sound went away, and the motor ran up again. Each time, it hits about 1500 rpm's and I kill it. But it seems like it will run up alot more. Maybe a reed valve? Help Please! Thank You
