gonefishing1
Thread starter- Joined
- Apr 3, 2010
- 18
1969 evinrude / Johnson 115 wiring help needed. Ok hear is my dilemma. I bought a force 125 to replace my old evinrude 115 that was running fine. I just wanted something newer with power trim. After messing with it more than I used it I decided to put my trusty old evinrude back on the boat. I have a shop manual that I?m trying to use but not all the wires are the same color as the book says they are. I only have four wires that I unhooked from the terminal block that come from the controls. I didn?t touch the wires coming from the rectifier, pulse pack, or stator. I also have the diode and lead assembly hooked up. , That I did take off, now the motor turns over sparks but when it starts it just shuts off. All the wires that I didn?t touch do not match up with my manual; they are in the wrong place, do I start over and pull all the wires off and make them match the manual even though it ran fine before I took it off? Please forgive me if I rambled or left something out I wanted to put everything down that I did. Your help is greatly appreciated. Thank you
