Pain'n'da'boat
Thread starter- Joined
- Jun 10, 2009
- 42
1981 90 hp Johnson outboard crossflow.
Took it fishing this weekend, never had problems with the starter before, go to start it and it made a wicked grinding sound, engine started. I killed the engine to pop off the engine cover and all the teeth on the starter gear are ground off nice and shiny..enough that I could not restart it at all...what could cause that to happen??
Do you think the starter solenoid got stuck engaging the starter gear to the flywheel and at too high of RPM's caused the starter gear to grind and strip out???
Any other idea's on what I should check before I just replace the starter? I don't want to burn up the new one so if there are any other things I should check out, please advise.
And iBoats has the cheapest starter ($20-$50 cheaper than anywhere else!!)
Awesome!
Awesome!
