1990 Evinrude 50 hp Wont Idle
repair man
It would not start and the vro siphoned into carbs. Drained carbs and decided that I would look at the fuel in the tank first before I went on. Fuel was dead so I drained the fuel and now I can get the engine to run but it will not idle. Took drains out again in carbs and flushed and added power tune now I notice there is a hose on the carb plate that holds the vro pum and attaches to carbs, This hose goes on the bottom of that plate and dead heads but the hose is bad and not hooked up. does this hose have anything to do with my problem, thanks
repair man
Re: 1990 Evinrude 50 hp Wont Idle
I forgot to mention that its also missing the roller,washer and o-ring for linkage and I will have those on monday
repair man
Please can somebody help me with this problem
