trouble with motor in water
hey i have a 1987 mercury 90 hp 2 stroke ob.you can start it and run it out of water and it runs fine in gear but when its in water and you put it in gear it will just bog and only go like 5mph. could this just be my plugs are bad?
Bob_VT
Re: trouble with motor in water
Welcome to iboats
You need to verify the spark on ALL cylinder's. A motor will "sound" fine when on muffs or in a bucket and will even sound smooth but.... you may not be firing on all plugs.
JB
I agree with Bob. Most commonly you have one or more cylinders that are not making power; maybe spark, maybe fuel.
Another common cause of this "runs great with no load" problem is the throttle failing to open all the way or advance the ignition timing all the way.
cjleigh
I agree with Bob as well. I ran into this same problem with a 6Cyl Merc that I had. Ran fine on the muffs but terrible in the water in gear. Turns out a cylinder was not firing due to a bad wire. I replaced the wire, and all the plugs just for poops and giggles, and she ran great after that.
Let us know if this solves the problem.
C.J.
i put 6 new plugs in it and a new fuel filter. it runs better has a little trouble starting and when you put it in gear and give it a little gas it it skips and dosent run good. if you give it alot of gas it bogs for a bit then it runs better but skips alot and seems to have trouble runing
and i also want to get a new prop for the motor and if anyone knew what pitch the prop is
Mi duckdown
Hold the phone.
First check compression on all clylinders.
2nd make sure you have spark on all cylinders.
3rd Buy an OEM Merc Manual for the motor.
now i have replaced all fuel lines cleaned all the carbs new fuel filter and rebuilt the fuel pump annd ran fresh gas with seafoam and the problem is still there it runs a little better but still bogs and skips like it wants to go then all of a sudden it will just come back to normal and take off and run mint till you bring the idle back down again then it does it all over again. anyone help?
