sltintexas
- May 28, 2010
- 109
I just rebuilt my carb. I had some serious idling problems and bogging prior to rebuild. It is running alot better. i suspect I am still missing something on my carb adjustments.
After it warms up I can shut down the motor and start it back right away with out issues. If it sits a while, it will need me to move throttle to wide open and it will start after lot of cranking.
Do y'all think its the idle air mixture? I had a hard time trying to figure that out.
Anything I could have done with the carb rebuild that is a little off?
I still have just a small hint of hesitation when I "gas it" from idle. Don't know if this is related or not. The problem of hesitation is much much better though.
motor is mercruiser 3.0LX 1996 serial number ok148861
mercarb 807504
mercarb 807504
