robcurtiss
Thread starter- Joined
- Jan 19, 2010
- 17
On a boat I bought a month ago, with an OMC 3.0L and Rochester 2GC carb, I had issues with it starting and running. A friend helped me rebuild the carb while at a campsite. We cleaned all the surfaces well, but did not tank the carb nor have compressed air to assist us in cleaning. The carb works MUCH better, but is still having idling/stalling issues, mainly after hitting some big waves.
I have discovered an air leak at the throttle shaft (idle changes when hit with carb cleaner)...
Is it worth taking it apart and rebuilding again (with proper soak time and such), knowing that the throttle shaft will still leak? Or should I just buy a new/rebuilt carb?
I'm looking at this one, what do you think?
http://marinecarburetor.com/Y39-2.htm
