ssmith32256
Thread starter- Joined
- Sep 12, 2009
- 31
I have a 1985 MCM190, 3.7L I cannot get the motor to turn over at all. I have tried with the starter as well as by hand. I have removed the spark plugs and pulled the outdrive off but neither had any effect. The engine has an integrated alternator on the front of the crankshaft so there is no place to get a socket / breaker bar on it. I did however get a crowbar between the three smaller bolts and tried to turn by hand. Didn"t turn but put enough pressure on it to break off one of the bolts. So here's my question, Am I screwed or is there something else I should check ? Is there anything in the shift linkage that would cause the motor to be locked in place ?
