OptsyEagle
Thread starter- Joined
- Sep 13, 2006
- 1,367
Ok, so I am trying to get a non-running 1976 15Hp Evinrude going. When I first obtained it, it had good compression (100psi on both cylinders) but no spark on either cylinder. I popped the flywheel and changed the points and set them to 0.020" and replaced both condensers. Presto, great spark with both, jumping about 3/8" gaps.
I fired it up and had a difficult time getting it to continue to idle, so I decided to clean and rebuild the carb. I also changed the water pump and since I think it had been in salt water before, I changed the T-stat (it was all corroded and the seal was gone) and replaced the water jacket gasket.
I fired it up in the barrel and it seemed to run great. Before I patted myself on the back, I wanted to see if both cylinders were running so I pulled each plug boot, one at a time. Well, when I pulled the bottom cylinder plug boot, nothing changed but when I pulled the top cylinder plug boot, it died. This told me that I had only one cylinder running. I then decided to switch the plug boots to see if the problem moved to the other cylinder. When I just switched the boots, I could not get it to start. When I switched just the coil connector clips, I could not get it to start. But, when I switched both the coil clips and the coil plug boots, it started. But guess what?, only the top cylinder is still running. I thought the problem would switch to the top cylinder and get the bottom running, but the top cylinder was still my only running cylinder. I should add that I am using two new Sierra secondary coils at the time. I changed them, not because they were defective, but because they were very corroded and had some cracks in them. From my experiment above, It would appear that they are both working OK with continuity measuring in at about 14.7 K Ohms each.
What's going on here? When I pulled the plugs (they were brand new gapped at 0.030" when I started this process) the top one had a little bit of oil residue, but the bottom one was still pretty shiny with no oil on it at all. The center electrode gave evidence of firing but the white insulation was very clean as opposed to the top plug had some slight brown dis-coloration.
I am thinking that perhaps water might be getting into my bottom cylinder but my question would be, would that keep it from running and could it have good compression numbers with a defective head gasket (assuming that is where it is coming from). My other thought would be reed valves, but I know very little about them.
Please help with any suggestions and advice? I am into weird territory here.
