spark plugs
micdin
i have a 1984 50 hp evinrude 2 cyl will a ngk buhw-2 surface plug work for that engine if not what will work thanks
wilde1j
Re: spark plugs
40, 48, 50 (2-Cylinder) 1980 - 1988 L78V Surface Gap or QL77JC4 .030
BRP always recommends Champion plugs.
Vic.S
Re: spark plugs
For what is worth BUHW-2 is the equivalent of L78V
The nearest NGK equivalent of QL77JC4 is BZ7HS-10
If you are forced to use NGK plugs take care not to use a resistor plug.
BR7HS-10 is not an acceptable alternative in an OMC CDI system despite the fact you'll often find it quoted as an equivalent of QL77JC4
