tmfd
Thread starter- Joined
- Aug 14, 2009
- 132
I don't get how the fuel pumping bulb goes bad? Walls lose rigidity or what? Anyway, my bulb does not get hard, yes that is as bad as it sounds
My motor runs fine for a while, then the bulb is flat and pumping it seems to get a little fuel flow. Disconnecting the bulb on the tank side and it fills up with air and regains it's original shape. But cannot seem to pump adequate fuel from the tank to the motor, almost like the line is plugged from the tank.
