82 evinrude broken shear key
COZMOS
What would cause shear keys to break.Replaced shear key yesterday,motor ran fine,shifted ok.So today we tried it on the water.Motor started fine but i forgot to put fuel hose from tank to motor and the motor stalled.I put the hose on but couldn`t get it started. when i got home i installed another shear key.Motor started up fine. I guess i idled down to soon and the motor stalled again. Im not sure but i think key is broken again.What gives? Sorry the motor is a 82 50 hp. the manual call for 80-85 ft lbs I went 85. thanks
Daviet
Re: 82 evinrude broken shear key
If you are talking about the flywheel key, it normally shears because of incorrect flywheel torque.
What is the model# of your motor and maybe someone can tell you the proper torque.
COZMOS
Yes it is the flywheel key . I replaced two and they both broke plus the original one also broke. My manual says 80- 85 ft lbs motor model # e5obecnr
Daviet
Make sure the crankshaft and flywheel yaper are clean, any thing that will not let the flywheel seat on the crankshaft will not allow you to torque the flywheel properly.
The key is there only to set the timing, the flywheel uses the proper taper fit and torque to hold the flywheel in place.
COZMOS
ls it possible for the taper on the flywheel to wear out? Mine looks a bit worn out.Possibly due to slippage.
F_R
Things that cause flywheel keys to shear:
1. Improper torque
2. Oil or whatever on the tapers. They must be shiny clean and dry.
3. Previously sheared keys. Every time it shears one, it damages the tapers and keyways. Do it enough times and you might as well junk it.
4. Over torqueing is bad too (read impact wrench). Spreads the flywheel taper. No way to shrink it back down again once the damage is done.
COZMOS
Hey FR when you said junk it I hope you mean the flywheel and not the whole motor
tx1961whaler
Depends. If the bore is spread from over-torquing, then the flywheel can be replaced. If the keyway is messed up from one too many broken keys, then the crankshaft is toast.... I do know a way to fix it but it requires machine work and you might as well replace the crank and do it correctly.
COZMOS
From what you guys have said it looks like my flywheel is toast.The key way on the crank shaft looks ok.Not sure what to look for but the shaft is not scored, the keyway is not spread.As for over torquing i don`t know. J just bought the boat. So who knows.I know i went by the book.Do i have to buy new or can i buy used.
tx1961whaler
Does not look to be available new.
Here's a list of other places:
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
tcoutboards.com
Tim's outboard 218-682-2331
