ewenm
Thread starter- Joined
- Mar 30, 2005
- 187
hi
i have a 32 foot boat with twin 4.3 efi mercruisers, this being my first twin engined boat
i have to ask, and here may not be the best place but here goes,
i get a noticeable vibration a thrum thruming noise, and wondered if this is normal for twins, i have 3 blade aluminium props and clean or dirty its the same
the only method of synchronising the motors is to balance the rpms with the tachos
and sometimes by slightly mismatching them i can reduce the vibration
the motors are solid mounted and there is no timber in the mounting points, its a fiberglass moulding that the mounts are through bolted to
it could be just twin motor harmonics, but i thought i would ask anyway
and do you think 4 blade props would help, i dont need anymore get up and go as this thing flies for its size and with full tanks (500 litres fuel and 280 litres of water) and 6 adults it easily planes and will run out to max rpm
so not really looking to change the props, however if it was thought that i could reduce the vib this way i would make the change
so what do yah reckon
Ewen
Ewen
