exodave
- Jun 8, 2010
- 107
Finally got my 1957 Evinrude 35 out in the water today, running fantastically. The issue now that we are out on the water, is that we will be cruising along 3/4 throttle or so, hydroplaning, then suddenly the RPMs go up and we slow down until we just bump the throttle down.
There aren't any shakes or knocks or kicks from the engine. it just suddenly whines high until we bump the throttle down.
The reason I expect cavitation, or prop not low enough, is that this transom was hacked up by a previous owner to lower the engine, which clearly wouldn't reach low enough otherwise. It is model 25930, which I think has a twin model which has a 5" longer shaft.
The top of the prop is maybe a couple inches below the lowest part of the hull.
btw, I have, indeed, sealed up all the exposed transom wood, which for some crazy reason wasn't done whenever this modification was made. Clearly must not have been in the water more than a few times this way before me.
