Most important Gauge to watch
Motormaniac801
Whats the most important gauge to watch on the cluster?
I hear people say "RPM", "oil", "water temp"...it cant be preference?
My boat (74 glastron with a 4cyl 140hp i\o MERC with the R series outdrive) runs great at full throttle and the temp sits right in the sweet spot, and water temp sits right in the sweet spot but my RPMs shoot to 6000rpm. This cant be good...but it hasnt done any "bad" that i can tell. needless to say, I dont crusie at 6000rpm for more than a min at a time. perhaps the calibration is off, bad gauge, or something.
jtmarten
Master Chief Petty Officer
Re: Most important Gauge to watch
Fuel gauge.
j/k
Sounds like the tach is off, 6K sounds really high for that engine.
seabob4
6 grand is really high! Need to do some TS'ing on that tach..Assuming tach gets fixed, engine temp first, then water pressure...
Scan your gauges about every 30 secs, just like you do in your vehicle...
seabob4
BTW, what are the conditions that exist when your tach "shoots" to 6 grand?
Bifflefan
For me the most important gauge is oil pressure.
Water temp gauge:
Your motor can live for quite awhile with no coolant at all, but will do damage eventully.
Gas gauge:
it will run until it runs out of gas, fill it up and go.
Volt gauge:
it will run with no alternator until the battery goes dead, Charge or change and go.
Oil Pressure:
Lose this and your engine is on its way out in 30 seconds, more than that and its time to drop some coin for a rebuild.
I have a gauge and a light on this.
rbh
All, just scan back and forth occasionally.
GatorMike
Ensign
Just watch where you are going......do you watch your gauges when you dirve your car? You just look at them every now and then. I keep sayin boating ain't rocket science.
Motormaniac801
it was reading 6k when i was at full throttle earlier today. engine sounds and runs great at full, but the tach says 6, seems way too high especially on glassy water with 1 other person on the boat. :confused:
Ill have to start looking into it seeing if i cant get some gauges that work. :rolleyes:
oldjeep
6K - either you are underpropped or your hub is spinning.
Silvertip
There are no "unnecessary" gauges. Some are just more important than others but whatever gauges your boat has should be monitored -- frequently. They indicate an immediate or impending problem. On a four stroke, loss of oil pressure is an engine killer. On any engine overheating is an engine killer. On any engine a non-functioning charging system cam leave you stranded. A water pressure gauge can tell you when an impeller change is needed or when then the impeller has failed. Waiting until it reads "zero" is a good way to kill an engine. A 6000 rpm reading on a tach may be good or it may be bad depending on the engine. The proper rpm reading is when you go wide open throttle with what you consider an average load the rpm indication is within the manufacturers recommended WOT rpm band. If it goes higher you need more prop. If it is lower than that you need less prop (or throw some weight overboard).
DianneB
For just about anything mechanical I would say the most important is to LISTEN! If you are used to the sound under normal conditions, you will pick up most problems by a change in sound. Scanning all the instruments regularly is second.
Fireman431
Cover your bases all the way around.
Oil - put a peizo alarm on the pressure side that activates at <10 psi. If the pressure goes out while underway, the alarm sounds to alert you.
Temp - S/A/A, but with a temp reading of 200 degrees.
Tach - put an adjustable rev limiter on the engine. It can't overrev with a built in limiter.
Fuel gauge - That's all you, my friend.
45Auto
The most important gauge by far is the trim gauge. If your motor is not angled correctly, the vortifluxer valve could easily be causing your motor to rev too high, sometimes to 6000 RPM or more ......
seabob4
GD Vortifluxer valve! Should've known!
Seriously, the real key is to keep an eye on your gauges. My Dad flew F-100/101/104s in the Air Force, you know how many gauges are on a fighter dash, they were taught to scan every 15-30 secs or so. We do the same with our cars and boats. Your engine will tell your RPM by sound. Your speed? Who really cares. But your temp gauge will give you an idea that your water pressure is down. Oil Pressure? Yeah, that's bad, but how often to you see breeches in the oiling system of your motor?
BTMCB
Agree with the "scan them all" crowd.
Stachi
way under propped,bad guage , or spinning hub at WOT,.. my best guess ...lol
Stachi
uhmm.. scan them all, thats what they are there for....sheesh !
All of those systems need to be monitored.... you will know what the gauge was doing just before the problem occurred as well...very helpful when diagnosing a problem...
Beefer
My 'entry level' Bayliner Capri has no guages. Nope, not a one. And that's from the factory. My ears tell me whats going on. I do look back to make sure the motor is peeing like it's supposed to, but it's all about the sound.
But... a tach tells alot about whats going on, so that's my choice for an install this summer.
seabob4
Now that is "Entry Level"!
