speed and tach work intermittently
jdands
I have a 99 seaswirl w/ 4.3 volvo penta. The speedometer works and then doesn't and the tach reads right and then wrong and then right again?:confused:
big_b
Re: speed and tach work intermittently
I would say lose ground/signal wire or even low voltage from battery/alternator.
Even a volt or two low can make some tachs read way off ...
CHeck wires and the charging system
jdands
Thanks much, will get back w/ results
Silvertip
The speedo is not electric so the issue with that is there is debris in the pitot or kink in the pressure tube that needs attention.
