notsunkyet
Thread starter- Joined
- Jun 8, 2009
- 198
ok heres one for you guys... 85 force runs great! (i know i know shocking) anyway when i have it tilted all the way up (as high as the tilt will go not using the tilt bar) and go to the lake, 7 miles away, and put in it will crank and crank until the starter gets hot and wont start. then out we go so i can sit on shore with it on the down position,for a few minutes and it will pop right off.... im wondering if the fuel is draining out of the carbs during travel and the needle an floats are being bounced around too much and i have to prime the snot out of it and let it sit for a few and then no issues..... yes i do use the choke and have put a new solinoid on recently as the old on was bad....any ideas?
Alos it has a 13 x 14 prop on it and can do about 30 on the water. not bad considering that we are not a skinny family lol anyway is this the best prop size or would a different pitch do us better?
