Guys, i'm hoping to garner a bit more of your knowledge.
I took the boat out of the water today to give her a bit of a scrub, and while on dry land I decided to check the oil level in the sterndrive... bad move. When I removed the dipstick the oil was really milky.
I took the prop off to check for fishing line, but there was none, but I noticed that the milky oil was leaking from the oil seal on the shaft... could this be my problem?
I would like to have a closer look but am having problems removing the housing
Do I need a special tool to remove this (it says nothing in the manual about removing the housing) it seems to be well fixed in place. I've removed both retiaining screws, and was thinking about a bit of careful jiggling with a fine screwdriver and hammer... plus a bit of heat. Would this be sufficient to remove the housing?
Any advice, tips, general ridicule all much appreciated
