1987 SeaRay 3.7L I4 165HP Oil Capacity
bwthor
Not sure how, but my dipstick went AWOL. I'd like to drain all the oil, fill to the proper capacity, then I'll engineer or order a new dipstick. Just need to make sure I'm at the proper oil level for dipstick calibration.
I found a .pdf file with capacities, and it shows 5.5 quarts, but I would have bet that I only used 4.5 quarts on the last change, which leads me to my next question. When I suck the oil out, how much is usually left in the crankcase?
Any suggestions?
Thanks in advance.
boattech
Re: 1987 SeaRay 3.7L I4 165HP Oil Capacity
Those engines would hold between 5.5 and 6 quarts. If you drain properly you should be able to add 5.5 quarts and remark your new dipstick. Be sure and run the new oil into the filter before marking the dipstick.
bwthor
Thanks much...great advise. Hope you enjoy the 4th!
