LakeMonster
Thread starter- Joined
- Jun 30, 2010
- 5
I have a 1982 90 HP Johnson that is acting very strange. I can have the boat out on the lake and it's running fine (defined as pushing 30 to 32 mph max) at WOT. All of a sudden, like a switch, the boat speed drops and begins to max out at 15 mph and I feel like I'm crawling across the lake (sounds like the engine is still at top RPM while this is happening which is weird). On another occasion, I'd be cruising at no wake speed with the engine seemingly running fine and all of a sudden the engine seems to run more stable (less shaky) and with some additional power. It seems, at these "stable" times, that the engine will hit the higher MPH if I were to punch the throttle. I can't link this to any temperature or amount of time out on the lake in one outing. It just comes and goes. I noticed some burn marks on the engine head by coil #1 so I replaced all the coils and plug wires (what's with the plug wires? They have a little hook that presses through the enter of the plug wire in the hopes that you can contact the core of the wire and keep consistent connection through the visbration of the engine on the lake) Anyway, after I replaced the coils and wires the problem still exists. I can be out all day and not have the problem occur or I can go out and have the problem there the entire time. Any advice would be greatly appreciated.
