Identify this hull?
Bus_Boy
Hello everyone, i have recently purchased a Zodiac 2.85.
I have searched long and hard, and i can not find any info on this boat whatsoever!!
I can't even find a single other Zodiac, of this length (anything under 3M) that is red, they are all white with a blue logo.
Has anyone seen one of these before?
Sea Rider
Re: Identify this hull?
Yes, what info do you need ?
Bus_Boy
Basically any info i can get.
The name given to it, such as cadet, fastroller, ect
Aprox year of make
Materials used during build
How they rate amongst other SIB's
Possibly thier price when new.
There's info on newer 2.85's, but they are all the white ones with blue acsent. I'm not sure if the design is the same/ similiar. I've searched all over the internet and i cannot find even one of these.
Normally i would take that as a bad sign. I mean if something was good, then it was most likely popular, with a lot of people purchasing. amd atleast some info on the net.
I fear i may have bought a dud?
SVKKAI
The boat appears to be around an early to mid 90s model. Check the last two or three digits of the HIN plate (back side of transom - to starboard) for the exact year. You can find part nomenclature at www.inflatableboats.com for replacement parts and other information.
Sea Rider
Some answers :
Cadet version.
Aprox year of make
Cadet starts around 90 till modern days, check transom plate if available.
pvc, if having dual tones, hypalon if having one full color and point nose.
Nice wooden floorboard sib, extended back cones compared to other brands cones.
Hard to tell, rather expensive, at that time besides Avon and some other sib manufacturer, there were not many options to pick from.
Both colors were manufactured at same time, has prevailed the white/blue color. Check bottom pic.
Manufacturers change from time to time color configurations or vary slightly the previous models just to be in touch with modern tendencies. It's like the evolution of a VW beetle through the years, this doesn't mean that your sib model is a bad performer, if it's in perfect shape, including fabric, doesn't loose air through tubes & seams. You are a lucky boater to own a classic vintage "oldie"
Happy Boating
