what year lower units will fit this eng
zenchal26
What year and size engs have lower units that will fit a 1997 ELPT0 SN-0G527011
achris
More fish than mountain goat
Re: what year lower units will fit this eng
That's 90hp, so any Bigfoot 60, 70, 75, 90, 100, 125hp from 1987 to current and 115hp from 1989 to current will bolt up. As to whether the ratio is right is another question...
Chris............
Faztbullet
Only the 1987-1997 70-90 hp will work as the driveshaft is different(smaller) on the 60 Bigfoot. The gear ratio is also different between the 3 and 4 cylinder engines and to use a newer 1998-05 unit you must change the shifter as they use a 6 jaw clutch and throw is different...
zenchal26
so its a big foot lower unit and 87-97 70hp-90hp thxs
