I just installed this engine to replace an ailing 1988 Looper. It has been in storage for a long time, but was advertised as low hours, and from the condition, I would say that is accurate. The engine started and ran at the dealers on an engine stand. I was told a compression test was done and everything was good and pressures were even in each cylinder.
I did replace the VRO pump because I was concerned with the condition of the diaphrams after being stored for so long. I've run 12 gal of 50:1 premix to ensure the VRO was working, so at first I attributed the hard starting to the rich oil mixture (VRO +50:1).
I also ran the first 6 gal tank of fuel with some seafoam (two weeks ago), and tried a spray can of decarb through the schraeder valve today. There has been no improvement even though I'm no longer running premix. I pulled the carbs and even though the bowls looked immaculate, I had the yard mechanic go through them. He found very little sediment. Still have the same problem after reinstalling the carbs. Did a compression test. Port bank are all about 100 lbs. Stbd side a little over 90 lbs.
The engine is very hard to get started and if it does, it may stall on its own, or if I try to advance the throttle it will usually but not always bog and stall. It wil not start in the neutral position. I have to advance the throttle to get it to start.
If I can get it on plane the engine runs pretty good and has never bogged or stalled while up on plane. It may have a bad coil or related problem as It will only rev to about 4500 RPM. I'll look into that more next weekend.
I found a thread where a a similar problem was caused by clogged recirc valves. Sound plausible?
Any other suggestions? I want to go back with as much info as I can, along with any special tools I need to troubleshoot.
The other engine was replaced for way low compression, but if I could get it started in the morning, it would start every time once the engine was hot. This is different.
Sorry for the long post, but I didn't want to leave anything out.
