fishingwoodchuck
- Jun 23, 2010
- 4
Any help on this would be greatly appreciated.
Here's the low down.
-about 6 months ago, I did a carb kit on all 3 carbs
-I changed both fuel filters
-I use marine Stabil everytime I put gas in
Boat had been running great after the stuff mentioned above. While at the lake, I was on plane and running almost full power when it suddenly just bogged, or ran down like if I had pulled the throttle back. So I then pulled the throttle back and it would idle just fine. I throttle up again and it would plane out and run for about 30 sec then the same thing. It did this until it fouled the spark plugs. Take the boat home and
-Changed the plugs (Champion L76V), and the top 4 were dirtier than the bottom 2
-pulled the carbs and checked the floats and fuel bowls, all very clean and no particles or trash
Back at the lake again, boat ran fine to first couple of fishing spots then it started all over again, this time when it starts to bog or run down, I hit the choke a few times to see if it wasn't getting enough fuel, but no change. This continued till the plugs fouled again. I had some extra plugs and changed them (actually only had four, so changed the top 4). It would start and idle just fine. I limped back to the dock slightly above idle (took over an hour), and when I got close to the dock I gave it one more try and the same thing would happen. It would plane out, run about 20-30 sec then bog.
Thank You for any Input!
