1985 Force timing marks
Rich1540
I would appreciate it if someone could post a pic of the timining marks !
I got it running pretty good but seems to be lacking a little when trying to get up on plain!
14' bayliner trophy ,50hp force
It seems to run great when I get it up gps speed is 38mph!
Prop is stock 12 1/2 293
Timing marks are missing ,thanks ! Love the siteit has been a great help with this!
Rich1540
Re: 1985 Force timing marks
Just read that if I set the points to .020 I don't have to worry about the timking marks is this true ,everything else is set to manual spec
Rich1540
Was just wondering if anyone knows if this is right !or can I get a pic of timing marks please thank you !:D
jerryjerry05
I don't think an 85Force has points.Do a compression/spark test.There should be 3 little lines about a 1/4" apart on the flywheel.It's 32-30-28 reading L-R
Unless you messed with something the timing won't really change too much.
I'd start with the carb.The air screw should be turned out 7/8 -1 turn out.J
Rich1540
I'm sorry its a 50hp force and put new points in it ! The timing marks above the carberator. Are gone ,flywheel has the marks but motor does not ,that's why I was aski ng
Thanks !
jerryjerry05
It'sa 1985 50hp Force? And you replaced the points?
The one I looked up doesn't have points.
What model and serial# for your motor?
I'm confused.J
Rich1540
Its a us marine 50hp force 1985
Serial# 1916
Model# 507x5a
Its on a 14'' bayliner trophy
jerryjerry05
Sorry,A mind is a terrible thing to waste(mines gone)#13 on this diagram.
Boats.net Force parts.Look for reed plate assy and it's #13.
Rich1540
Yes it is ,thanks will order one really appreciate the help !
Happy boating thanks!
