Crownline 250 prop
jhilton
I have a Crownline 250 1994, 7.4 carburated motor. It ran 5250 rpm with a 17p Mirage and 42mph. It also ran 5000 rpm with a 19p ballistic 41 mph. I have a 21p mirage i will be trying in a week from now. My question is what 4 blade prop would you recomend. I have to cruise at 4000 rpm, 31 mph currently and:confused: My gas milage is terrible.
usskydvr
Re: Crownline 250 prop
The Mirage is better than the Ballistic for your larger boat. That is why your RPM came down (expected) and top speed actually went down 1 MPH with a prop that had 2" more pitch.
You didn't say which lower unit and gear ratin you had but for a 4 blade
you might try the revolution 48-857026A46
see http://www.mercurymarine.com/propellers/prop-selector/#
jhilton
Bravo 1, Ill have to check the ratio. Thanks for the reply.
