water leaking into bilge, volvo penta sx outdrive
01-4winz
so I put the boat in the water the other day and opened the rear hatch to check the oil and as soon as i got the rear hatch open i heard a water leak. Its tough to see where its coming from but looks like its coming in through the outdrive right under the drive shaft. any ideas? this sound like the bellows?
01-4winz
Re: water leaking into bilge, volvo penta sx outdrive
umm nothing? bump
ENSIGN
Sounds like a good place to start.
bruceb58
When was the last time you took off the drive? Time to do it and replace/inspect your bellows.
01-4winz
just had the bellows replaced last year...
01-4winz
well i found a small tear in the bellows.... we had the shop change it last year but i'd like to do it myself this time. anyone have a good wright up on this? do i need some special tools?
bruceb58
Do you ever run your engine with the drive tilted pretty far up? What brand bellows did they put in? I would use the OEM bellows.
01-4winz
anyone have a decent wright up on this? im trying to decide if i can do this myself or if im better off bringing it to a shop.
bruceb58
Its pretty simple. Pull the drive and pull the pivot housing. You need a 1/2" hex driver for the pivot bolts.
