Screws loosen in fiberglass - not stripped
security6
The screws that hold the captain's chair to the deck in my boat keep loosening. I can retighten them and they hold, so they are not stripped. However, after an outing or two they are loose again. The boat is a 2000 Larson Escape which has a fiberglass deck. The screws go directly into the fiberglass deck. Is there a "lock-tite" sort of compound that will work so these screws don't keep loosening?
saildan
Re: Screws loosen in fiberglass - not stripped
Fastened just into the fiberglass, no backing plate or anchoring block that's dropped away?
Fill the holes with epoxy and re-drill them to the proper size for the screws like the chair was being installed for the first time.
Philster
You can add some epoxy/filler to give the screw more bite.
Saying something "stripped" would apply to a male-thread-to-female-thread connection.
Essentially, they ain't stripped, but the fiberglass/wood/whatever is a tad to big for a tapping screw to bite. You need too make each hole a wee bit smaller.
If you remove and replace tapping screws again and again, nothing strips, per se, but the hole loses bite when it slightly enlarges.
robert graham
Fill screw holes with epoxy to tighten up their grip, run a bead of silicone rubber around and under pedestal base, then re-attach the screws. Silicone will help level and hold pedestal in place.
180Fisherman
If the screws are pulling out fix as described above. If you think they are just backing out from vibration or whatnot maybe some lock-tite will work
Home Cookin'
or--fill the hole, drill out the hole, use a "tap and die" to thread the hole, install with bolts.
ufm82
Master Chief Petty Officer
Do you have access to the underside of the deck? If the chairs are fastened with screws and you can access the underside I'd consider going to bolts and backing plates. My pedestals were screwed into the deck and were loose but I was able to get to the underside through the fuel sender access plate. I installed SS bolts into SS backing plates and they have never come loose again- very solid.
UFM82
dingbat
Screws on a boat are a joke. Any load bearing connection should be thru bolted with backing plates.
security6
Thanks for all the replies.
I'll have to see if I can access the underside of the deck where the screws are. There is an opening in the deck right above the gas tank that I have never removed. Perhaps it is time to take it off. I agree that if I can access it, I am best off with a backing plate and bolts.
For epoxy, would 3M 5200 work? If not, do I just pick up a fiberglass kit at the auto parts store?
ufm82
5200, while being very agressive and strong, is not an epoxy. After curing, it is still rubbery. I would use a true epoxy or even MarineTex instead. If nothing else works and you have the ability, you could always just bump up a size in hardware. Assuming you have a 1/4" screw holding things together...
UFM82
